Open carriers use scanners hanging around prison
#1
Aside from the abnormal actions of hanging around a prison or going near schools, if you listen you'll notice particular audio and see it. The law enforcement was aware of it too.
This does not help the folks against a particular subject. So in aspects many will see this and you can guess what will happen.
We all know what is legal. But do normal people do this? You want attention you will get it and with current times I believe law enforcement was in the right in cases like this. It furthers my opinion on use of secure measures communications wise where problems exist or may exist.
Open carriers linger around a prison and using scanners to monitor law enforcement in open monitoring movement and prison operations.
https://youtu.be/AN16bCuCNu0
