Opinions on this...
radio10-8
West Coast
I have seen these before and I have mixed results, Mostly negative. I think they are in the same catagory as the Pringle's can antenna. For a prosumer like us on this site I would say stick with an antenna that was designed for scanner with BNC connection.. http://www.cantenna.com/
mancow
N.E. Kansas
For less than $5 you could do it yourself.
I used two slinkys for leggs of a dipole a while back and it worked fairly well. It's a good way to go if you don't have alot of room.
gcgrotz
Charlottesville
The Slinky dipole has been around for a while, except now slinkys are made of plastic. I have a sneaky feeling they wouldn't work too well as an antenna, and I know for a fact they don't go down stairs as well as the metal ones did.
