OPP FleetNet and DSDplus Solution
Chester_Field
12AU7 / ECC82
Round Lake Centre ON
Greetings
Someone mentions that DSD does not work for OPP FleetNet trunking. Is this correct?
Is there a SDR solution for FleetNet?
Cheers and Thanks!
mciupa
Canadian DB Admin
Moderator
I'm here a lot
A better bet would be to join the Unitrunker Google group. Once you are approved, you would be allowed to download Unitrunker V.2 and would be able to trunktack the OPP.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
No, DSDPlus will not work for Fleetnet.
I prefer to use Trunk88-SDR.
slicerwizard
Toronto, Ontario
I've used DSD+ with a Fleetnet site's voice channels in an FMP24 scan list. It's not ideal, but it's gotten the job done. Analog calls (EMS, whatever) get ignored, which is fine by me.
Sounds complicated. And the OP is using an RSPdx; no support for that in TRUNK88.
Chester_Field
12AU7 / ECC82
Did it work for the OPP?
Sorry - Whats a FMP24 scan list?
Cheers and Thanks!
Forts
Ontario, Canada
Yes it works.
FMP24 is the dongle tuning software included with DSDPlus. It can also scan a list of proprogrammed frequencies.
Chester_Field
12AU7 / ECC82
Yes it works.
Thanks.
Indeed it does work. I used SDRuno, Virtual audio cables and pointed it at DSD. Set up a scan list and omitted the control channel and away it went. Very cool.
Cheers
