OPP Toronto - East
#1
Why is it there is a feed for OPP in the downtown area but there is none in the east end.Can any one broadcast Whitby OPP, Downsview OPP , and Toronto OPP, it would bennifit a lot of other listeners also.
mciupa
DB Administrator
Moderator
#2
Can any one broadcast Whitby OPP, Downsview OPP , and Toronto OPP, it would benefit a lot of other listeners also.
Live Audio Broadcasting is purely voluntary. Maybe someone will read this post and consider doing one for that area.
Until then, you will have to be patient. :(
Toronto, Canada
#3
What part of "downtown" does the OPP service ? Nor do they do the "east end". Keep in mind the OPP services the 401, 407 and 400. The feed is labled Greater Toronto Area OPP which most likely covers from about Burlington to (I believe) up to hwy 115/35.
EJB
Downtown Hamilton
#4
What, no hello, no ? marks? No civility?
If you had one you wouldnt have to rely on anyone else for your fix.
Toronto's Downsview detachement are referred to a 5 Foxtrot and they are patched with Durham units out of Whitby, 5 Kilo.
East end unit? No comprende homes.
Solution:
B-U-Y- A-S-C-A-N-N-E-R
