OPP Tower Collapse - Powassan
mikewazowski
Staff member
Central Ontario
#3
3rd party contractors.
They were probably doing a plumb and tension on the tower. Guy wires are tightened and loosened to bring the tower back to straight and make sure the guy wires are all tensioned equally.
buddrousa
NW Tenn
#5
No one has said anything about the tower crew lets hope nobody was on the tower at the time and all the ground crew is safe.
exkalibur
York, Ontario
#7
no interruption of service is what the news article stated , how would this be possible or do the towers over lap slightly in the coverage
In "most" places you can usually pick up at least two if not three or four Fleetnet towers. They're not going to be spectacular, but good enough for slightly degraded performance.
