Dawn
Looks like the company that made these special for Yeticom in NZ's specifications decided to bypass the OEM and go direct themselves with these unit. From what I gather, they are very refined and high quality built versions of the Magnum257/Radio Shack HTX-10 with totally different firmware and optimization for amateur use with high spec and extra filtering. GW itself is sold in the states as Instek and is an OEM for many of the test equipment manufacturers including lower end Tektronix products. Not a slouch of a Taiwanese company that's know to make pretty high grade equipment. Sort of ironic though, GW started as a company knocking of Leader test equipment products for OEM brands and then their own designs were knocked off by the Koreans, who were then knocked off by the Chinese producing copies of 1990 versions of GW designs. These radios are made in very small batches as a departure from their focus on test equipment and Telecom/IT product lines. Anyone know anyone who owns one of these? The difference between a Magnum 257 and one of these, even though they look similar as many of the Chinese and other Asian ones do, are supposed to be incredible without the filthy RFX type power module bolted on the back, very stable and spectrally clean with a very tight receiver. There's a couple of companies selling them on E-bay for not much more then the Magnum's and similar knockoffs and sounds like a great radio if you want a real 10M unit instead of an "export" in disguise as one.
