Option QA01767 apx series radios
Town of Islip, NY
#1
I was wondering if this option QA01767: ASTRO 25 TRUNKING RADIO AUTHENTICATION means that the radio has to affiliate and be permitted on the system before the radio would pass audio. In other words does this option prevent the no affiliate scan method from working on p25 phase 1 or phase 2 systems. This is just for my curiosity as i don't own any apx series radios.
clbsquared
Isle of Wight County
#2
If I'm not mistaken, it allows authenticating radios to ensure they have a valid SUID (account) in the system. I don't think it's an issue for the scan method. But I'm not 100% sure.
Sent from my HTC One A9 using Tapatalk
#3
The system can require you to authenticate before you can affiliate to the system. This option allows your radio to do authentication with the system. Without this option, the radio will be denied affiliation. Note that if you are using a scan only approach this doesn't stop your radio from transmitting. Also, having this option is meaningless to non-affiliated scanning. Having it won't hurt just as not having it.
Sent from my SM-G935P using Tapatalk
