Orange 911 fire disp. & pine bush ambulance question
Orange county, NY
#1
Hey guys I'm looking for sum frequancys is there a VHF freq for orange 911 fire dispatch or r thy all UHF? Also does anyone know pine bush ambulance corp radio frequency? Thanks!
#2
Orange County 911 - 154.205 pl 123.0, Countywide FD Dispatch.
Pine Bush EMS - 157.45 PL 136.5, Countywide EMS Dispatch, Response on 153.86 pl 77.0
Also, check out East Coast Scanning Resources.com
#4
The PL (Private Line) or CG (Channel Guard), is a number to put into your scanner after the frequency if you have two (2) different agencies on the same frequency, only to hear the agency you want to hear. Please go to top of the RR page, click on Wiki. When you asset it, in the search box on the left side of the page put in CTCSS.
k2hz
Rochester, NY
#7
I don't believe the PRO-135 is capable of PL so just enter the frequency and you are all set.
If a scanner has PL capability, it is useful if you want to hear only the desired system and block other signals but it is not necessary for ordinary monitoring.
#8
Here's some other frequencies i found for Pine Bush.
FD- 45.64, 460.6375,465.6375
EMS - 155.325
