Orion cable ca101288v4 with a DB-15?
Thunderknight
Bletchley Park
I have an Orion control cable that appears to be normal control cable, except it has a high density DB-15 (like a VGA monitor connector) on a short tail that comes off the control head end. The connector has a weathertight cap on it.
It's marked CA101288V4
When I Google it, it looks like it's an extended option cable. But I'm confused as to the purpose of the DB-15? I thought any options would come off of the option cable (the other control head cable).
WCRadioGuy
Salisbury, MD
This is an external programming port. This extends a pigtail to an accessible location for programming the radio instead of having to unmount the radio and disconnect the DB37 from the rear.
ElroyJetson
I have one of those. I could use the pinout or part number for an adapter cable so I can connect it to a programming PC.
Frankly I'm mystified as to why they'd use a DB-15. I'd think an industry standard DB-9 RS-232 connector would be a lot more sensible.
But very little about M/A-Com seems to make a lot of sense.
Elroy
LID109
Midwest
Elroy, check the programmer or RPM help file. The pin out for that DB-15 to DB-9 programming cable is there. You can also keyload and run mobile data through it....that's why it's got 15 pins :)
