Orion VHF Hi-Band Mobile with ERR-0401
BlueDevil
WA
We have a couple Orion VHF Hi-Band mobile radios that intermittently show ERR-0401 when attempting to transmit. A simple power cycle of the radio seems to resolve the issue until it randomly happens again. When the radio is working it doesn't seem to have any problems.
Thoughts? Suggestions? Radio Recovery procedure?
Thunderknight
Bletchley Park
That means it is going out of lock. It could be getting too warm, or you could have a low voltage issue, but is likely the radio needs to be realigned on the bench.
BlueDevil
WA
Just seems weird that it can be reset by a simple power cycle and it is so random even operating on the same channel.
timkilbride
Linn Co Iowa
Do you know if this is a 256k or 512k radio and are you operating below 150mhz?
It has been my experience using a 150-174, 256k Orion below 150mhz the VCO will un-lock. I have moved many Orions down into the ham bands and every single one of them had VCO unlock issues using the 256k boards. The 512k radio's I never had a issue with down to 144mhz.
Tim
BlueDevil
WA
They are operating in the 155mhz range. I am not sure which board they have in them.
BlueDevil
WA
The department is starting to phase them out however they are still using a lot of these in the mean time.
