ORNGE Air Ambulance
rfsparkz
Angus Ontario
Hello does anyone know what frequencies the ORNGE ambulance service in Ontario generally use ? Thanks Russ VE3ELL
Thunder Bay ON
What mciupa said. But don’t expect much traffic on the frequencies. My understanding is that most of their operational communications are now done via satellite devices.
FWIW, we see a very large, almost constant amount of ORNGE aircraft movement in our area, and today was the first time in weeks that I’ve heard any radio traffic.
CG-YNM ORNGE heli is in the air overhead here right now, and there is no radio traffic whatsoever. Even ATC comms are limited.
EJB
20 + year membership
Downtown Hamilton
Yup. If you live near a trauma hospital you'll sadly hear them pretty much on a daily basis in the GTA and SW Ontario.
VA3SOM
Ontario, Canada
Very rare to hear traffic on them here, except their ATC traffic where they refer to themselves at "Lifeflight One/Two Medivac" (i think that is them at least)
mikewazowski
Staff member
Forums Manager
Oot and Aboot
You can watch them on most aviation tracking sites:
LF1, LF2 Toronto
LF3 London
LF4 Ottawa
LF5 Sudbury
The fixed wing aircraft are PULxxx.
Currently LF2 is north of Shelburne.
fmoore
Ottawa, Canada
I have heard them on the Tactical channels that EMS will use to Patch with the Emergency Dept. I assume it is standard province wide so monitor your local TGIDs on the Bell system.
ATCTech
FWIW, some flight tracking sites will display the helos under their civilian registrations, for example:
C-GYNJ
C-GYNO
C-GYNP
On the UHF dispatch repeater (413.6875) this will be heard as "799 Juliet", "799 Oscar" etc. The London/Windsor unit I believe flies as "792(x)". Ottawa and Sudbury/North Bay I can't remember, but I have heard 798(x) units.
The fix wing aircraft (PULxxx as mentioned above) are callsign "PULSE ###" when talking to ATC on en route frequencies.
Cheers!
Bob
ATCTech
Does ORNGE use ADS-B? Any suggestion on what flight track site to use?
Yes, the A139s have it. I see them on Flightradar24 all the time under the civilian regs. listed above, like right now. And there's my answer about the YOW unit, it's C-GYNL working up there at the moment.
74652
74653
