Just to correct this info,
Osceola County Fire Rescue Station 65 is a joint station with Polk county fire department. The station is physically located in polk county at 1201 cypress parkway. it houses polk county ladder 34, tanker 34, als 27(rescue 34), osceola engine 65, rescue 65, and brush tanker 65. The old station 41 which was located on marigold was demolished after the hurricanes, then osceola did a renumbering and added an engine once moved into the new station, then once again the county did a renumbering and is now 65 since the division of the county into 3 battalions. Also as of Oct 5 polk county ems is no longer in this station since polk county fire is trying a merger and now als27 is staffed with polk county fire personell and will be renamed to rescue 34 very soon. Hope this helps.. On the scanner side of things, Osceola is dispatched on Tac 1 and response on Tac 3, polk is dispatched on Tac 1/VHF and respond on Tac 5 unless its a fire then on Tac 10
