OSP map
LawnCowboy
Cincinnati (Hamilton Co. West)
Didn't there used to be a map in the database identifying the different districts? I can't find it.
hearing a lot of traffic from Toledo, Wooster and other far off areas in the Cincy area... reason? I'm sure this has been covered before but too lazy to go looking :)
B
16b
Central Ohio
http://www.statepatrol.ohio.gov/publications/Post Brochure.pdf
If you want printed copy, you can probably hit up your local patrol post. The last time I saw them at OSU recruiting, they had piles of 'em.
To answer your second question: it's because those talkgroups are affiliated with whatever site you are listening to. This is because a MARCS user in your area is listening to those talkgroups.
