OTAP (POP25) Questions
Demitryk
I have a 7.8 trunk from what I'm told is capable of OTAP.
How do i find out for sure that it is?
What feature sets are required in the radios?
I understand how to setup the code plug and the CPS portion but how do I configure ARS Data Administrator Application?
how do I know what IP address to use? Is this a server at my master site?
How do you interface the CPS to the radio network?
Any help is appreciated.
vans113
Tennessee
I know the answer to some of the questions not all of them.
First you had to order the radio with the otap feature, or you should be able to buy this feature from motorola and flash the radio.
2nd your going to need access to a pop 25 (otap) server if you do not own one Im sure your sales rep can get you one not sure on the cost. if you do not own one you're going to need a data line into one for a connection to it.
Also I will tell you pop 25 is VERY SLOW dial up internet is 56k I belive pop 25 works at 9600? also voice trumpts data so if you go to otap a radio thats on a main channel good luck. sorry I don't have the answer to all your questions.
Demitryk
My radios have the OTAP feature set.
So the ARS is a phyiscal server at my matser site?
vans113
Tennessee
I believe just a computer with the software on it is really all it is. Never seen it honestly
