Otero Couty Simplex 1 frequency
#1
Hey guys anyone know the frequency for a channel called simplex 1? I heard our sheriffs deputy calling for Care Connect (flight for life) to help look for a lost person he told his dispatch he was gonna switch to simplex 1 to talk to Care Connect (flight for life)? thanks in advance
Bennett Colorado
#2
It's a direct (simplex) non repeated frequency on the state dtrs system. 851.1000mhz 293nac tone. Its line of site only so usually not heard out side 1-2miles from scene. On the database under Colorado state agencies there is subgroup called Colorado mutual aid you can find several other common used simplex channels there as well.
Sent from my SM-G960U using Tapatalk
