Ottawa area DMR
Ottawa, Ont.
#1
What looks like the first 850 MHz DMR in the Ottawa area, that I know of, is a Capacity Plus system
on 860.8375 and 861.0875 MHz. It was idle as of a few days ago, but may be some activity on it now.
These frequencies were used by the old C&W Moto trunked system 462f which is gone now, mostly...
On that note a couple of 462f system channels are still active in failsafe mode, constant carrier with slow
beep every ~10 seconds...862.5625 and 863.0625.
Dave
Ottawa, Canada
#4
Here are the DSD windows:
-DMR slot2 BS DATA ERR3 DCC=2 Rate 3/4 Data FEC FAIL
-DMR slot2 BS DATA DCC=5 CSBK ERR1 Cap+ RestCh=3
[LB=1 CSBKO=62 (?) FID=16 v16=E300 id1=0 id2=0]
3E 10 E300 000000 000000
101111100001000011100011000000000000000000000000000000000000000000000000000000001100000110110011
-DMR slot1 BS DATA ERR1 DCC=5 CSBK ERR1 Cap+ RestCh=3
[LB=1 CSBKO=62 (?) FID=16 v16=C300 id1=0 id2=0]
3E 10 C300 000000 000000
101111100001000011000011000000000000000000000000000000000000000000000000000000001011101011011011
-DMR slot2 BS DATA DCC=5 CSBK ERR1 ECC FAIL
-DMR slot1 BS DATA DCC=5 CSBK ERR14 ECC FAIL
Sync: no sync
