Hello . Does anybody knows how to program out of band the following model : MOTOROLA CP180 ( MDH65KDH9AA4AN ) 146-174 MHZ ? I understand that CP040 can be tricked by changing some data in codeplug as follows :
The task: Program CP040 H50KDC9AA1AN 146-174 at 145.500 MHz.
Read radio with CPS and save file codeplug.cps.
Open file codeplug.cps in HexWorkshop, find Hex "BBA5A5A5A5A5A5".
You will find it three times.
First entry is "A4A5A6BBA5A5A5A5A5A5". It is Motorola VHF Base frequency - 103.000000 MHz.
Second entry is "A4A1A3BBA5A5A5A5A5A5". It is lower limit - 146.000000 MHz.
Third entry is "A4A2A1BBA5A5A5A5A5A5". It is upper limit - 174.000000 MHz.
So alphabet seems as follows:
A1 = 4
A2 = 7
A3 = 6
A4 = 1
A5 = 0
A6 = 3
AD = 8
BB = "."
Change lower limit to "A4A1A1..." and save file.
Open file with CPS , enter frequences and program radio. Save codeplug on disk.
Problems: Radio possible to program ONLY ONCE.
Radio works orderly, but is not read and is not programmed by CPS.
Needed to save data from EEPROM IC and restore at need of reprogramming,
or use Radio Firmware Kit.
Thank you.
A1 = 4
A2 = 7
A3 = 6
A4 = 1
A5 = 0
A6 = 3
AD = 8
BB = "."
Thank you.
