Hello everyone, first forum question. Regarding outside antennas whether it is on a house or tower.
That's more of a physical question. How high is this antenna? Are you installing from ground level or on a roof top? I have one antenna on a short mast mounted from the roof, and a second antenna that is on a long mast mounted from the ground. The height of the antennas are fairly close to each other.
Can that antenna be hooked up to a mobile or handheld police scanner with the same results. As you may guess, bigtime newbie here.
Generally speaking, the results are the same. But as mentioned here in other replies, all radios are not identical. Different brands, models and intended purpose will have varied results.
I think the biggest thing people don't realize when they install their (first) outdoor antenna is downlead. Coax is not your friend. That signal can be quite strong at the output of the antenna and be completely wiped out by the time it reaches your receiver simply due to attenuation through the downlead coax. The higher the frequency, the greater the loss. It is important to consider the antenna and coax as part of an "antenna system". This would include things like grounding, lightning arrestors, filters and amplifiers/multi-couplers; to name a few. Don't skimp on the quality of the coax.
