P 25. What is out there to listen to on digital?
Figliano
Burlington, Ontario
I currently have a PCR1000, but I am trying to find out what is out there to listen do in digital mode.
I have been searching RR but cant seem to locate possible groups in ontario. I'm sure there must be some out there. I'm in the Hamilton,Toronto, Halton area.
Can anyone help me out with this? Are these Trunking systems?
What would I be able to listen to if I get a digital scanner and where can I find this info?
Thanks in advance
Mike
hypersight
Canada
- OPP and MTO Carrier Enforcement use digital (trunked)
- Peel and Toronto has a few intel talk groups which also use digital (trunked)
- There's a few OPP and CISO conventional channels that are digital as well
All the mentioned agencies above can be found in the database on this website.
mikewazowski
Staff member
Central Ontario
exkalibur said:
Toronto is encrypted I'd say 50% of the time. Peel is rarely encrypted.
Peel's Intel talkgroup is generally encrypted 100% of the time and the other channels see little to no use at all.
VE3RADIO
Planet Earth
That is more along the lines of what i have found. I guess the point is, the only clear and reliable p25 is OPP, MTO and GO Transit.
torontokris
Toronto Canada
To answer the OP's question
yes a trunked digital scanner will be needed to follow them correctly. Almost any digital scanner (as long as it has a digital card) should work.
In the case of Go transit you will need a newer scanner that does 9600 baud (pro96 396 etc etc)
exkalibur
York, Ontario
I guess I must be listening at the wrong times. Heard quite the operation not too long ago, over the span of 5 or 6 hours around Dixie Road...all in the clear.
hypersight
Canada
I was listening to that too...about 2 weeks ago I think? I believe it was on TG 16464.
