What exactly is the difference between the P25 auto and manual choices?
I'm having a hard time finding much about this setting and what it really affects in operation.
Does it have to do with the system threshold settings that can also be changed for each TSYS?
I'm attempting to monitor the Starcom system in Illinois. I can hear the control channel but the signal is weak. 2 bars on the PSR-600 and 1 bar on the BCD996T.
The BCD996T has a manual setting for controlling the P25 decode rate and it is set to 9 for this system. The 996T receives the system very well. The PSR-600 barely decodes anything. The radios are both fed from a Stridsberg MCA208 multicoupler.
I could have an overload situation here which I'll deal with but first I'd really like to understand the meaning of the P25 Auto and Manual settings if anyone cares to share that info.
Also, are the Threshold High /Low settings the same thing as the Decode Rate manual adjustment available in the BCD996T? If not then is there a similar setting in the PSR-600 that can be adjusted for each P25 system?
I also monitor the cities P25 system but on the 996T it needs a manual adjustment set to 5 for the best decode rate which is a bit away from the Starcom's setting of 9.
Thanks for any help.
