P25 Control Channel BCD996T
traumacop
Newark, Ohio
Forgive me if I have missed this searching the other threads,
I am trying to program a BCD996T with a MARCS site, but I can't get it to program Control-Channel Only Mode.
Reading page 81 of owners manual it says
"Setting Control-Channel Only Mode M (except for P25)"
Does this mean Control-Channel Only Mode is not available on the 996?
UPMan
Uniden Representative
Arlington, TX
P25 systems always use control-channel only mode, so there is no need for a setting. However, MARCS is not a P25 system. It is a Motorola Type 2 system with APCO-25 voice channels. The sites should be programmed as Motorola Type II/800.
traumacop
Newark, Ohio
Thanks a bunch.
It is crazy how terms or slang for terms can cause such confusion (especially before a sufficient amount of coffee).
Now that you say that, I do remember reading the P25 vs. APCO 25 topic before.
Thanks again
