P25 in Roswell and Carlsbad
abqscan
DataBase Administrator
Moderator
AOA
Do you know if the P25 option was purchased for the radio? It doesn't come from the factory with it and is an $800 upgrade.
William2910
Land of entrapment
It's more than likely the op to that was confused not his fault as digital believe it or not is new to most of NM.
You are correct I believe his radios aren't capable. Not his fault. Digital is new for NM and the protocols for the varieties.
As for the others I cannot add with the information I know directly due to non disclosure there is A LOT of new stuff out there barely coming online in NM specially in southern NM not in the DB. From Hobbs to Lordsburg all the way up to Clovis. Some having delayed until recent.
Yes unfortunately E is in a lot places that is popping up or will depending where, and what is going on. This includes fire, public works, police, dog catcher.
Most was accurate until recent this year but keep in mind the old analog can be used as fallback still in most places and is maintained (for now) so that one is a tough one with RR polices from what I've seen as far as deprecated to in use.
As most know who are in NM holding onto existing things seems to be a common thing in rural NM even if new is being used.
William2910
Land of entrapment
I have submitted the proper PL tones for the listed Carlsbad city frequencies.
Also the proper now p25 detention frequency which is same as old but in mixed mode on repeater with proper NAC.
It should be important to note the repeaters are in mixed mode and analog is still maintained with existing tone on anything that has gone p25 in this region.
For record I'll keep the nac and tone here so anyone wanting to adjust their scan list as such has the tone for jail/detention tac.
141h NAC 107.2 PL mixed mode.
