KA1RBI
[cross-posted from op25-dev]
Locally we have a Motorola system that runs in the 800 MHz band and is believed to be running with LSM. I have been having extreme difficulty in achieving correct symbol recovery from any of the channels in this system, even though the signal strength is very strong here (there is another more distant P25 system, weaker on the receiver S meter, that comes in 100% perfectly).
I've read that LSM uses CQPSK modulation; that it uses a pulse-shaping filter that is slightly different than the "standard"; that C4FM is used for the uplinks, LSM is used on the downlinks only; and that there is some controversy as to whether it should qualify as fully "APCO P25 compliant...
It is also interesting to note that the Radio Shack people have introduced a firmware upgrade to the DSP software for their scanner radios which supposedly make these radios work with LSM now.
When looking at received signals on the datascope, there are periods where everything looks fine, with four distinct horizontal bands, but there are frequent "hits" in which the entire display is filled with random noise.
There is a Motorola PDF file (can upload if anyone is interested) that talks about LSM but is not very technical.
Also I've heard that in order to properly receive LSM (and CQPSK) requires an I/Q receiver. This would imply that the Radio Rausch decoder (which is excellent for what it does work with) would not be usable. This is because the Radio Rausch decoder accepts demodulated baseband (float) input rather than I/Q (complex) input...
Also have tried using the Gnuradio mpsk_receiver block on it but it won't even phase-sync with the signal. The mpsk_receiver block is going to need extra code someday, so that it understands PI/4, but even so it should show some semblance of trying to lock to it, which this isn't.
Any ideas or tech tips would be *much* appreciated!
Thanks & 73
Max
Thanks & 73
Max
