P25 Opcode 0E Mfid 90
johnmoe1
Dakota County, MN
I have seen this message a number of times:
0e 90 0a 00 00 00 00 00 00 00
It seems to mean something like "this control channel is shutting down".
mikey60
Oakland County Michigan
Do you have something context with other messages that show this one occurring? Control channels rarely change on the system I monitor, so I've never seen this message, if that's what it is.
I would expect a new control channel number to be a part of that message , which I suppose 0a00 could be. On a "Standard" 800 Mhz Motorola system, that would be in the 867Mhz range.
Mike
WayneH
Forums Veteran
Super Moderator
Your master site
I'm curious what drew you to that conclusion. Is this a new system? This is either something new (like in 7.15, or maybe 7.14) or some rare occurrence as I've never logged it and I've logged data during shutdowns, switches to Failsoft, etc and it's never been there.
Like Mike says, context would be more helpful.
Wayne ... next time you're able ... force a change in control channel and see if John's message shows up.
PiccoIntegra
North Texas
Here's some context for that opcode.. see attached file. There is two minutes before and two minutes after. There is a small gap after the CC changed(OP25 had to reacquire the new freq). The contents are identical to the op's post.
I think I reported this to the Pro96Com yahoo list about this same opcode last June (when this log was generated).
I did observed on one occasion that this opcode was transmitted, but the CC did not change.
  • 20140612-Dump-101-OPCODE-0E.zip
johnmoe1
Dakota County, MN
I'm monitoring 11 twin cities area ARMER sites in MN using my own software/SDR.
The last time I definitely saw it was when site 1-1 went down (I would guess for maintenance). Forum post when it happened: http://forums.radioreference.com/mi...orum/309631-metro-sit-1-01-a.html#post2356581 I no longer have my logs going back that far for more context.
I definitely don't always see it when a control channel stops. I do not know for sure if it is because it is not transmitted or if it is transmitted after I have already switched frequency (I switch based on adjacent site messages). Could it also be that it is only transmitted for scheduled maintenance or something? I've also considered making a change to only switch control channels after a packet is missed.
I searched my last just more than 96 hours of logs and the message was not present even though one site (1-4 Carver/Scott) switched frequency 6 times.
mikey60
Maybe when a site is going off-line... It's sent multiple times. I've never seen it in any of my captures. I would guess the third octet is a reason code of some kind.
Mike
talkpair
Clinton County, MO
After some filtering tricks with PiccoIntegra's file, it's interesting that opcode-mfid 0E 90 seems to have an effect on octet 7 of another mystery opcode-mfid 05 90.
Code:
  05 90 40 00 00 01 41 [COLOR=Red]6D[/COLOR] 00 00 4C 50  06/12 13:45:22 Unknown Op=05 Mfg 90(Motorola)
  85 90 40 00 00 01 41 [COLOR=Red]6D[/COLOR] 00 00 A8 64  06/12 13:45:23 Unknown Op=05 Mfg 90(Motorola)
  05 90 40 00 00 01 41 [COLOR=Red]6D[/COLOR] 00 00 4C 50  06/12 13:45:23 Unknown Op=05 Mfg 90(Motorola)
  85 90 40 00 00 01 41 [COLOR=Red]6D[/COLOR] 00 00 A8 64  06/12 13:45:24 Unknown Op=05 Mfg 90(Motorola)
  05 90 40 00 00 01 41 [COLOR=Red]6D[/COLOR] 00 00 4C 50  06/12 13:45:24 Unknown Op=05 Mfg 90(Motorola)
  [COLOR=Red][COLOR=black]85 90[/COLOR] [/COLOR]40 00 00 01 41 [COLOR=Red]6D[/COLOR] 00 00 A8 64  06/12 13:45:24 Unknown Op=05 Mfg 90(Motorola)
 [COLOR=SeaGreen] [COLOR=black]0[COLOR=Navy]E 90[/COLOR][/COLOR][/COLOR] 0A 00 00 00 00 00 00 00 BB 3B  06/12 13:45:24 Unknown Op=0E Mfg 90(Motorola)
  0[COLOR=Navy]E 90[/COLOR] 0A 00 00 00 00 00 00 00 BB 3B  06/12 13:45:24 Unknown Op=0E Mfg 90(Motorola)
  8[COLOR=Navy]E 90[/COLOR] 0A 00 00 00 00 00 00 00 5F 0F  06/12 13:45:24 Unknown Op=0E Mfg 90(Motorola)
  0[COLOR=Navy]E 90[/COLOR] 0A 00 00 00 00 00 00 00 BB 3B  06/12 13:45:25 Unknown Op=0E Mfg 90(Motorola)
  8[COLOR=Navy]E 90[/COLOR] 0A 00 00 00 00 00 00 00 5F 0F  06/12 13:45:25 Unknown Op=0E Mfg 90(Motorola)
  05 90 40 00 00 01 41 [COLOR=Red]4B[/COLOR] 00 00 78 36  06/12 13:46:31 Unknown Op=05 Mfg 90(Motorola)
  85 90 40 00 00 01 41 [COLOR=Red]4B[/COLOR] 00 00 9C 02  06/12 13:46:34 Unknown Op=05 Mfg 90(Motorola)
  85 90 40 00 00 01 41 [COLOR=Red]4B[/COLOR] 00 00 9C 02  06/12 13:46:37 Unknown Op=05 Mfg 90(Motorola)
  05 90 40 00 00 01 41 [COLOR=Red]4B[/COLOR] 00 00 78 36  06/12 13:46:40 Unknown Op=05 Mfg 90(Motorola)
  05 90 40 00 00 01 41 [COLOR=Red]4B[/COLOR] 00 00 78 36  06/12 13:46:43 Unknown Op=05 Mfg 90(Motorola)
  05 90 40 00 00 01 41 [COLOR=Red]4B[/COLOR] 00 00 78 36  06/12 13:46:47 Unknown Op=05 Mfg 90(Motorola)
  85 90 40 00 00 01 41 [COLOR=Red]4B[/COLOR] 00 00 9C 02  06/12 13:46:50 Unknown Op=05 Mfg 90(Motorola)
  05 90 40 00 00 01 41 [COLOR=Red]4B[/COLOR] 00 00 78 36  06/12 13:46:54 Unknown Op=05 Mfg 90(Motorola)
WayneH
Forums Veteran
Super Moderator
Your master site
Ok, I'm bringing up a new site soon so I'll try some things. I can see if there's an embedded reason code too.
Opcode $05 (90) are mostly hold-off timers. I haven't - not sure about others - pinned down the exact bit lengths to timing values yet.
johnmoe1
Dakota County, MN
2015-03-19 Rice County,MN (ARMER)
Site: 3-44
Primary: 851.8
Alternate: 851.975
Code:
3a 00 00 34 0f 03 2c 00 7f 60
39 00 03 2c 00 9b 04 00 9b 04
3c 00 00 34 0f 03 23 05 95 70
00 90 07 ee 07 ee 07 d7 07 f8
05 90 40 00 00 00 00 00 00 00
09 90 0d c0 00 00 00 00 00 00
30 00 00 04 2a 1e 73 9c 22 08
3b 00 00 be e0 74 0f 00 7f 60
02 00 01 ab 08 dc 01 ab 08 dc
3d 00 13 25 e0 32 09 15 75 62
0b 90 b2 69 2c 24 52 80 00 b7
3c 00 00 34 0f 03 29 01 a1 70
30 00 00 04 2a 1e 73 9c 22 26
3d 00 03 22 d0 32 0a 25 10 a2
00 00 04 01 ab 08 dc 01 9d 41
0e 90 0a 00 00 00 00 00 00 00  <=== 2015-03-19 14:33:07.489
(851.8 MHz stopped transmitting; I switched to 851.975 MHz)
3c 00 00 34 0f 03 23 05 95 70 <=== 2015-03-19 14:33:07.714
3c 00 00 34 0f 03 28 00 43 70
3c 00 00 34 0f 03 2a 03 41 70
3c 00 00 34 0f 03 2b 00 57 70
3c 00 00 34 0f 01 03 01 99 70
3c 00 00 34 0f 01 04 00 e5 70  (it really thinks we should know about adjacent sites)
09 90 15 40 00 00 00 00 00 00
30 00 00 04 2a 1e 73 9c 22 94
3b 00 00 be e0 74 0f 00 9b 60
3a 00 00 34 0f 03 2c 00 9b 60
39 00 03 2c 00 7f 04 00 7f 04
09 90 07 80 00 00 00 00 00 00
3c 00 00 34 0f 03 14 00 d7 70
30 00 00 04 2a 1e 73 9c 22 a8
09 90 0a 00 00 00 00 00 00 00
3c 00 00 34 0f 03 19 02 45 70
30 00 00 04 2a 1e 73 9c 22 c6
30 00 00 04 2a 1e 73 9c 22 da
30 00 00 04 2a 1e 73 9c 22 f8
No 0e 90s were present when it went back to the primary:
Code:
02 00 00 0f 4e 58 00 0f 4e 58
09 90 0c 80 00 00 00 00 00 00
30 00 00 04 2a 1e 73 9c 56 12
00 90 07 ee 07 ee 07 f8 07 d7
30 00 00 04 2a 1e 73 9c 56 30
30 00 00 04 2a 1e 73 9c 56 58
05 90 40 00 00 00 00 00 00 00 <=== 2015-03-19 14:34:46.039
(851.975 MHz stopped transmitting; switched to 851.8 MHz)
3c 00 00 34 0f 03 23 05 95 70 <=== 2015-03-19 14:34:46.339
3c 00 00 34 0f 01 04 00 e5 70 (again, a big stream of adjacent sites)
09 90 1b 80 00 00 00 00 00 00
30 00 00 04 2a 1e 73 9c 56 b2
30 00 00 04 2a 1e 73 9c 56 d0
09 90 0b 40 00 00 00 00 00 00
30 00 00 04 2a 1e 73 9c 56 ee
30 00 00 04 2a 1e 73 9c 57 0c
johnmoe1
Dakota County, MN
More of these message. This time not all associated with a change in control channel frequency. I guess I no longer have a good guess as to what this means.
xx = missing message (crc failed)
Code:
3c 00 00 34 0f 03 29 01 a1 70 <== 2015-03-25 11:15:22.114
00 90 07 ee 07 ee 07 ee 07 ee
30 00 00 04 2a 1e 79 81 ea 00
xx
0e 90 0a 00 00 00 00 00 00 00 **
xx
30 00 00 04 2a 1e 79 81 ea 1e
3a 00 00 34 0f 03 2c 00 7f 60 <== 2015-03-25 11:15:29.014
transmission ended; switched to 851.975
3c 00 00 34 0f 03 23 05 95 70 <== 2015-03-25 11:15:29.391
30 00 00 04 2a 1e 79 81 ed c0
05 90 40 00 00 00 00 00 00 00 <== 2015-03-25 11:16:29.014
transmission ended; switched back to 851.8
00 90 07 ee 07 ee 07 ee 07 ee <== 2015-03-25 11:16:29.390
30 00 00 04 2a 1e 79 82 0d c0
05 90 40 00 00 00 00 00 00 00 <== 2015-03-25 11:22:04.490
xx
xx
xx
xx
3b 00 00 be e0 74 0f 00 7f 60 <== 2015-03-25 12:01:24.965
xx
xx
xx
xx
xx
xx
xx
xx
xx
xx
xx
30 00 00 04 2a 1e 79 88 2b a4
xx
02 00 00 df 10 6a 00 df 10 6a <== 2015-03-25 12:14:38.165
xx
xx
xx
xx
3a 00 00 34 0f 03 2c 00 7f 60 <== 2015-03-25 12:56:31.865
xx
xx
xx
xx
xx
30 00 00 04 2a 1e 79 8f 0f 3c
xx
xx
xx
3d 00 03 22 d0 32 0a 25 10 a2 <== 2015-03-25 13:10:25.940
02 00 01 ab 10 ce 01 ab 10 ce
xx
xx
00 90 12 d8 12 da 12 da 12 da
xx
30 00 00 04 2a 1e 79 91 4c 30
xx
3a 00 00 34 0f 03 2c 00 7f 60 <== 2015-03-25 13:24:11.390
xx
xx
xx
xx
xx
xx
xx
30 00 00 04 2a 1e 79 93 04 92
05 90 40 00 00 00 00 00 00 00 <== 2015-03-25 13:45:00.815
xx
xx
xx
xx
xx
xx
xx
30 00 00 04 2a 1e 79 95 9e 46
09 90 0c 80 00 00 00 00 00 00 <== 2015-03-25 13:45:30.440
30 00 00 04 2a 1e 79 95 ae 4c
xx
xx
xx
xx
xx
xx
xx
02 00 01 07 58 59 00 0f 08 dc
xx
39 00 03 2c 00 9b 04 00 9b 04 <== 2015-03-25 13:55:59.389
xx
xx
xx
xx
xx
xx
xx
(skipped one that nothing but invalid crc around it)
3c 00 00 34 0f 03 19 02 45 70 <== 2015-03-25 18:55:32.839
30 00 00 04 2a 1e 79 be ef 8c
xx
xx
xx
xx
00 90 07 d7 07 f8 07 f8 07 ee
