How can I find out if the frequencies I want to listen to are or will be encrypted?
Use the search functions on your scanner to find control channel(s) frequencies and/or wait for others to find them and post/submit them to the RRDB / library.
You might be able to do some Google searches to learn about encryption possibilities but probably not. Beyond that, you won't know until it happens.
Just a warning - Uniden attempts (as much as possible) to "hide" encrypted talkgroups from scanner users... that is, under many conditions, even if you have the system/control channel(s) programmed, you won't even know that encryption is in use unless you look very closely and know what to look for.
If the system turns out to be fully Phase 2 (actually using Phase 2 mode/TDMA for it's talkgroups), I believe you will be able to detect encryption in use with the Uniden - but it will only sound like gibberish.
