P25 Phase II, how to calculate base freq and offset?
ElroyJetson
Does anyone have a method or procedure to determine the base frequency and channel spacing of a P25 Phase II TDMA system, calculating from the published frequency lists in the RR database?
An example to work with would be the Apopka, FL Phase II TRS. Why that one? Why not? Top of the
list in alphabetical order.
greenthumb
Colorado DB Administrator
It's a configurable parameter in most systems, so there isn't a sure-shot way to know it without having that information from pro96com or the system itself. You can usually deduce 6.25 kHz spacing on a 700 system, but the base can be different across 800 systems and can be either 6.25 kHz or 12.5 kHz and work just fine, depending on the base. For VHF or UHF systems, the spacing can be just about anything.
It really doesn't matter whether it's phase I or II - both slots refer to the same frequency...just different slots.
ElroyJetson
I should expand on my earlier comments a bit. I'm not using a scanner. I'm using appropriate two way radios with appropriate features and software that are fully capable of listening in. (They will not be permitted to transmit, using every appropriate programming trick and even hardware mod necessary
in order to achieve this.)
Specifically, I'll be using a Harris (M/A-Com) P7100ip with all features, up to date firmware and DSP code, and RPM 9 to program it.
The programming of this will be slightly different than programming a scanner.
I don't have a tutorial or guide for setting up a TDMA system in RPM but exploring the software has
given me some clues.
I'm still really unclear on whether the 700 MHz channels should be treated separately from the 800 MHz channels or treated as the same group of channels.
greenthumb
It's the same group of channels for 700 MHz and 800 MHz (in the control channel list) but a different IDEN set. A 7100 won't do P25 Phase II or 700 MHz...
The IDEN set programmed into the radio should match what is programmed into the system, which can be captured via a variety of sources (pro96com being the easiest), or it potentially won't work right. Radios should read the IDEN sets off the air, but Harris (being low QA/QC on their software) sometimes does it and sometimes does not. But really, my thoughts don't change whether this pertains to a scanner or radio. Scanners calculate the frequency the same way that a radio on the system does.
If you had a P25 Phase II capable Harris radio, you would just need to have the correct feature enabled, the TDMA box checked on the system and have the radio programmed with XGPR1 (or higher) radio code.
ElroyJetson
I should SOON have a working P7200 which will do Phase II, I think, but for now I'm still going to use the 7100 to learn the rest of P25 programming.
I had (and still have) no documentation on the IDEN channel set. I'm not even sure what it is exactly, but I'm pretty sure it has nothing to do with the Motorola/Nextel iDen format.
Interestingly, RPM does allow me to choose full rate or 2 slot TDMA in the IDEN channel assignment screen, when the radio type is set to P7100. I don't think the 7100 is TDMA capable so that's kind of interesting.
WayneH
Forums Veteran
Super Moderator
Your master site
You're going to need to run software like PRO96COM as you need to know the TDMA IDEN message details. Each identifier OSP includes a number to identify it from the others, which when wrong makes the radio useless as all calls reference this for proper calculation of frequency. There will be a second IDEN OSP for TDMA.
Motorola uses a manufacturer specific OSP to identify this second range for TDMA. So I'm curious how Harris will do this. Probably generate their own and also interpret Motorola's for compatibility reasons.
GTR8000
NY/NJ Database Guy
BEE00
I could be wrong, but I don't believe that's the case. If it were a Motorola specific OSP, the second octet would be "90", not "00". Here is a Phase II system reporting both the FDMA and TDMA IDEN_UP messages:
Code:
3D 00 03 22 D0 32 0A 25 10 A2 63 A0 Identifier Update 0 Base 851006250 Spacing 6250 Tx Offset -45000000
3D 00 13 25 E0 32 09 15 75 62 1B 36 Identifier Update 1 Base 762006250 Spacing 6250 Tx Offset 30000000
33 00 23 38 40 64 0A 25 15 84 48 4B Identifier Update 2 Base 851012500 Spacing 12500 Tx Offset -45000000 Slots 2
33 00 33 A5 80 64 09 15 75 62 75 FC Identifier Update 3 Base 762006250 Spacing 12500 Tx Offset 30000000 Slots 2
GTR8000
NY/NJ Database Guy
BEE00
That's interesting, though. I've got logs on a few different Moto systems, I haven't seen any $90 IDEN_UP messages for Phase II systems.
Is it possible that those are for X2-TDMA OSP's, and not Phase II? That would explain the Moto specific message.
GTR8000
NY/NJ Database Guy
BEE00
The ones I posted were from 700 MHz Moto Phase II systems (three separate systems broadcasting the same OSP's).
I assume it's possible that an X2 system that has been upgraded to Phase II might still broadcast the same IDEN_UP OSP's. Probably in addition to the Phase II OPS's, though. I'm not certain, I have no logs from X2 systems, unfortunately.
WayneH
Forums Veteran
Super Moderator
Your master site
Yeah, I'm not exactly sure yet and still learning the OSP structure and P25 CC personalities. And I don't want to take over Elroy's thread also. My first paragraph in my first post should still apply though.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Just checked a freshly installed Motorola P25 system near me and the IDEN_UP messages all show $00 for both FDMA and TDMA ranges.
Looks like $90 might be X2 only.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
This is correct from what I've seen doing my traveling and tracking. I don't remember where, but somewhere in my travels, I've had an X2 system's iden data come up on a nonstandard TSBK.
tsalmrsystemtech
So yes I am trying to understand when reading ProCom96 too. I read this info and it really interest me.
So I used procom on a 400 mhz system which is a Moto Phase I FDMA system. I believe I am looking at the Packet Data and the second octet is reading 90. What does that mean? As well as when I am programming a radio which is not a scanner but a commerical grade radio I am looking for this line which is the updated identifier table RIGHT?
Thanks. Just trying to learn like the rest of us.
