P25 static?
New Jersey
#1
P25 phase 1 and 2 are both digital correct? Listening to certain TGs when the car/ portables transmit and don’t have a good connection they sound like a analog radio with a weak signal to a repeater, I thought with digital there was no static it gets “pixelated” for lack of a better term.
#2
Phase 1 is FDMA, phase 2 is 2 slot TDMA overlaid on the FDMA channel.
There could be digital TG's that are patched, via the console, or other means, with analog channels.
Sent from my SM-T350 using Tapatalk
New Jersey
#3
This is the TG, I was pretty sure they are all phase 2. I’m gonna try to get an audio clip, not that it’s a big deal just curious
W8VFD
Northeastern Ohio
#4
Static
Our statewide system here in Ohio is 700/800MHz P25 phase 1, there are some agencies around me who use VHF analog vehicular repeaters tied to the digital radios. Sometimes when they're too far from the car I hear "static" caused by a noisy signal into the VHF analog receiver on the vehicle repeater. It could be what you're hearing, I'm only guessing since I don't know.
