P7100Programming version
bg2fx
Hi, I tried to program my P7100 using ProgrammerSetupR18, but the software said the radio was programmed with a higher version. I then used a Harris RPM14C05, but the software said the radio was programmed with a lower version. Please use R12 or higher.
Can anyone tell me how to downgrade the version, I will try to use ProgrammerSetupR18
merlin
DN32su
Well, I have used RPM 14C05, for years and for about everything Harris.
I think what ever bandplan you have in the radio is lost or wiped.
Using v14, just make a new bandplan, blow it into the radio without downloading first.
That will unlock the P7100.
>> SAVE your features and configuration with maintenance before writing to the radio.
Programmer is for older MaCom type radios, use RPM.
bg2fx
I will try, thank you
