PA speaker
AronDouglas
Southeast Georiga
Hope this is the right section, figured it would best fit here.
Does anyone have any suggestion on a good PA speaker? I'm not looking for a PA system, just a speaker for a 959 Galaxy. With some general looking, 100 watts looks to be what I want, but I don't know just yet. Something in the range of 100db +. Is the radioshack 100watt PA speaker any good?
AronDouglas
Southeast Georiga
After a bit more reading, 100 watts is not what I'm looking for. I dont know why the Radioshack PA uses 100 watts and only offers 100ish db. I'm looking for a PA speaker that offers 110db or greater.
cabletech
Puget Sound
Are you going to use the speaker for out door listening/pa funcation, or just to listen to the radio out side the car or is this for inside the car?
Any normal out door 8 ohm speaker rated at 20 watts or better will work for out side, and any normal
8 ohm speaker rated at 5-20 watts will work inside the car.
Just because a speaker is rated at 100 watts, does not mean that the radio will drive it at 100 watts.
To get the 100 watts you will have to use a audio amp in line.
110db is a federal noise limit that even emergency sirens have to adhear to, so for you to try and get some thing louder is not going to work.
good luck
AronDouglas
Southeast Georiga
Yes, I do plan to use it outside. While I am in the market for a external CB speaker for inside my truck, thats not what this thread is about.
I know that 110db is the federal limit, so if I get something louder I wont be using it on federal roads.
astark
Arkansas
I recently picked up a ASPC20 PA speaker off eBay for twenty five bucks plus sixteen shipping. It's a 20 watt built in amplified six inch PA speaker that is water and weather proof, is plenty loud and clear, and fit under the hood of my 1970 Bronco just fine.
I just did an eBay search and the cheapest I found tonight was eighty nine with free shipping, but I would still highly recommend.
W8RMH
Feed Provider Since 2012
I believe a CB radio's PA function is only 5 watts anyway, so regardless of the speaker's capability it will only put out 5 watts. Those 100 watt speakers are intended for emergency siren systems which do have 100 watt or more amplifiers.
Cabletech's reference to a 110db is a federal noise limit pertains to the speaker manufacturers. It has nothing to do with "federal highways". Check your state vehicle code as most states prohibit the use of any PA from a moving vehicle.
