Pantech UML295 External Antenna Connector
UT843XX
UT
#1
I have a data modem that will be permanently installed into a vehicle. It is a Pantech UML295 manufactured for Verizon's 4G LTE network. ( https://www.verizonwireless.com/support/4g-lte-usb-modem-uml295/ )
I am having trouble locating reliable information about what type of external antenna connectors this modem has. Some results in Amazon for adapter cables reference it as a "pigtail", others as "TNC", and others as "TS9". I am hoping someone can provide some expert confirmation or analysis as to what type of connectors these are for sure. I've attached an image file of the antenna connectors on the modem. Could you help me properly identify these connectors?
My end goal is to find the adapter to connect it, and some good NMO-HF magnetic or trunk lip mount with cabling with which to connect it to, where I'll have two external Pulse Larsen SLPT698/2170NMOHF antennas.
flux4201
#5
The adapter i linked in my earlier post converts the modem from its connector to a SMA Female, since you have an antenna with a FME female, they wont mate. You need this adapter linked below to connect the pigtail i linked in the other post to the antenna you purchased.
https://www.amazon.com/DGZZI-2-Pack...ME+male+to+sma+male&psc=1&smid=A23YDYH2AP2C8X
In total, you need the following to connect that antenna you purchased to your pantech modem:
https://www.amazon.com/dp/B00W65XXW4?tag=viglink20662-20
and
UT843XX
UT
#6
Excellent. I'll buy them and report back. I'd rather get the adapters than lose the money spent on the perfectly good antennas. Thanks for the info.
sfd119
#7
Just a word of advice, I would go with a Cradlepoint modem instead of a USB/Hotspot device. You'll have better connectivity. I've found that even with an external antenna, I would still experience signal issues and rebooting issues with those devices.
UT843XX
UT
#8
Thanks for the recommendation - though I'm pretty happy with the setup I have. It's been running flawlessly.
UT843XX
UT
#9
So you are absolutely right. The firmware on the USB modem locks up frequently and is not reliable. I wasn't seeing it before because it was rebooting regularly as a result of my changes on my network config while I was testing. Once I stopped making changes and hence no longer rebooted my router, I began to see the USB modem locking up in less than 48 hours.
I'll be taking your advice and looking for a different solution. I'm interested in the CradlePoints as well as some particular MikroTik's with their US LTE miniPCIe cards.
sfd119
#10
Your best bet would be a CradlePoint. Very easy to manage and they are pretty much plug and play. You can find some used ones on eBay for pretty cheap. Just make sure you research the model numbers to know that it'll work with your Carrier of choice.
