Papd/teb Frequencies
2WAYMAN
New Jersey
6-24-06 5:23 PM EDT
Hello all........
Does anyone know which, if any, of the PAPD EDACS system talkgroups listed in the RR Database are used at TEB Airport?
The only frequencies for the airport which I can locate on any of the boards shows
OPS 460.8250, PL 179.9 and 130.575-no PL; MAINT 460.6750, PL179.9 and a conventional 800 PAPD frequency of 866.7500, no PL or DPL found.
73's !
Thanks in advance.
2WAYMAN :)
crashcrew
The Isle of Lucy
On the EDACS system, they use EWR Patrol and ARFF talkgroups. Radio designations are Rescue 1 and Teterboro 1 and 2. Be advised though, not much activity. It's a quiet little place.
2WAYMAN
New Jersey
6-25-06 1209 HOURS EDT
Hi and thanks "crashcrew" for your speedy reply.
What about the two UHF channels I had lsited, they used to be licensed and used byt Johnson Controls when they ran OPS at the airport. Also, is the 800 conv. channel I listed used at all and if so do you have a PL/DPL for it?
Thanks and 73's!
2WAYMAN
crashcrew
The Isle of Lucy
The UHF channels are probably being used by PA Ops, but don't know...just a guess.
The 800 I believe is one of the mutual aid ITAC frequencies. If I find out more I will advise.
