The Par End Fed is 45 ft. and covers 1-30 Mhz. The MFJ version has lengths between 23-125 feet long and has different coverage. Made different? Which is better for 1-30 Mhz coverage? Thanks
Sure any wire will do it. I'm using #12AWG stranded coated wire for my 45' counterpoise. My 100' antenna wire is #12AWG solid bare wire that's been up there about 6 years so far.Let us know what you find out tailgator911. I plan to start with the regular Par End, then go from there. How do you add wire to it though? Ridgescan, I still have a long wire from radio shack I never used. I'll get the part number and post it. Will this work for counterpoise wire?
Even if your antenna and radio are the same, you really can't compare performance between you and a remote radio. Different region of the country will propagate differently on HF, height of the antenna, any extras the remote might have (additional filtering, etc.) are all going to play a role. Just go for the best you can get for your area. Mike
It’s I think 100 feet of bare wire. Planing on attaching the box toward bottom of tree, run about 15 feet, then out to a pvc pole that I will set up. Now if I double the length down the road, then can put the end on another tree. Should be here Monday. North/south is the best? Does Par make an extension wire to add more wire to the original?Sure any wire will do it. I'm using #12AWG stranded coated wire for my 45' counterpoise. My 100' antenna wire is #12AWG solid bare wire that's been up there about 6 years so far.
Adding wire to the PAR is easy just be sure that you secure the PAR trans box mount sturdy enough to handle extra wire in wind and stuff pulling on it.
For your counterpoise wire I think 45-50' long is best-no need to run 100' counterpoise from what I've read.It’s I think 100 feet of bare wire. Planing on attaching the box toward bottom of tree, run about 15 feet, then out to a pvc pole that I will set up. Now if I double the length down the road, then can put the end on another tree. Should be here Monday. North/south is the best? Does Par make an extension wire to add more wire to the original?
