Pasco Trunk
usafk9dan
Spring Hill, FL
I think pasco added a new cc. I came up with
855.81250
856.83750c
857.83750
858.38750 new cc
858.83750c
859.83750
860.8375
855.22500
856.22500
and it works again.
clawhammer
West Central Florida
I noticed that to today while I was over on the west side of the county today, I thought something had happen to my mobile antenna and checked it out and everything. It was ok and radio was fine. I added that frequency into the bank and I can also confirm that everything is working just fine now.
Allen
Bolt21
Point of Pines
You typically can't just "add" a new freq to an EDACS system. The "new" freq is the previously discussed rebanded replacement for 860.8375. 860.8375 should be deleted and replaced with 858.3875 in the LCN #6 slot. While it might be a cc today, it might be a voice channel tomorrow, and if it's not in the proper channel slot, you'll miss parts of conversations.
epicdrome
As long as you leave the old control channel in you should not have a problem at all
clawhammer
Got up this morning and notice that there are 2 control ch now. 855.8125 is showing CTL-01 w 97% and 859.8375 is showing CTL-05 sw 99% I do have to say that reception has improved here is Zephyrhills when I use to get only 83-85% on the CTL channel.
clawhammer
So far the Channel line up that I have programed in the radio as of now is working very well, have not missed any transmissions.
LCN1: 855.8125
LCN2: 856.8375
LCN3: 857.8375
LCN4: 858.8375
LCN5: 859.8375
LCN6: 858.3875
LCN7: 855.2250
LCN8: 856.2250
tampatracker
Thanks, I put that in as well and as of this time have not missed any transmissions either.
