Passport Trac/Passport Display programs
jcardani
Orlando, FL
I just wanted to share some pictures of the Passport tracking and display program and hardware that I have been working on for quite a while. I recently converted the program from DOS based to Windows console. I also have programs that trac and decode LTR and Multinet. Multinet does not have good error correction code yet).
There are 2 circuit boards. The first is the Daughter board and is connected to a Connect Systems LT-2 LTR decoder. The board replaces the microcontroller in the LT-2 and it has a PIC microcontroller onboard. The LT-2 does the low pass filter and slicing while the daughter board does 300bps bit timing and bit banging out the LT-2's com port. In addition the LT-2 passes carrier operated squelch ot the com port.
The second board (Interface board) interfaces the PC with the radio and LT-2. It passes the LTR data and squelch data to the PC over the com port, and controls the ICOM to change frequencies via CI-V commands. There is also a speaker mute circuit operated with a relay.
Right now this works with the ICOM R7000 and other CI-V radios with a discriminator tap. I hope to add support for Uniden and GRE scanners in the future. These radios would require a disc tap.
Enjoy the pictures of the boards here. I will upload screenshots of the program in the next post.
jcardani
Orlando, FL
Here are screenshots of the Passport programs in operation.
  • Passport Trac on Adler system.doc
  • Passport Trac on NJTA system.doc
  • Passport Display on Adler.doc
Living in N Florida there is a public safety department in my area using the Multinet system... I'd love to give my thumb a break and find a way really monitor this system. It is Clay County, FL.
fineshot1
NJ USA (Republic of NJ)
I tried more than a few times to obtain one of those LT-2 decoders but always got outbid.
I'm guessing that the receiver used must of course be able to do narrow band?
I have a RS Pro-2042 with the Opto OS-535 I/F and not sure if that will work.
Highpockets
Toms River, New Jersey
His IC-R7000 shows FM on the display for the freq used.
fineshot1
It works in FM and FM-N modes on the radio.
OK - I guess I should have worded my question differently.
The RS Pro-2042 was never a narrow band radio(before the NB era).
With the addition of the Opto OS-535 I/F is the RS Pro-2042 NB receive capable?
If not it will not work properly. I think it does have all else thats needed.
mondaro
Harrison, New Jersey
Joe...
Thanks for sharing this, It goes without saying many of us really depend on this feed especially during snow storms, I am still wondering why the NJTPA and GSP went to a system like this and it seems many people at both Authorities that used to monitor the plows are not happy as well.
Thanks You for a job well done !!
Tony
