I see there is a place to check for "password", but I can't find anywhere to put a password in. Also, when I checked "password", I programmed my SDS, and it was locked, and I had to re-program it without "password" checked, in order to use it again.
So, what am I doing wrong?
A possible scenario if you are actually programming an SDS scanner with the Sentinel software...…..
You probably have Sentinel set to the wrong target model (BCDx36HP). From the top Sentinel toolbar click on "Tools", then "Target Model", then select your scanner.
What you are seeing with the Sentinel target model incorrectly set to BCDx36HP is the Keypad Lock function used only for the BCD436HP scanner (look up at the top of that section where the check box is and you will see the text - "Options for BCD436HP Only"). Also, there is no password used for that function, and there is no mention of the word "password" associated with that checkbox in Sentinel... hence the confusion from your post.
On the BCD436HP keypad, you press the function button, then the power on/off button to toggle the keypad lock on or off (again, no password used). This does not apply to the SDS scanners, and does not function on those scanners. You may be able to set the keypad lock function on or off on your SDS scanner using the incorrect target model in Sentinel, but since the SDS models do not fully support that function, you can not lock or unlock it from the SDS keypad.
When you have the Sentinel target model correctly set for your SDS scanner, that keypad lock checkbox is not available in the software settings.
Check it out and let us know.
