Pastor: Remove 'Demonic' Books from Public Library
Davenport,Fl.- home to me and the gators and the s
#4
Hitler did the same thing, almost that is.
Removed and burned. That would be the ultimate goal of that preacher too. Burn baby burn. Way to go to control us. On a side note though; do away with books that are about supernatural, remove books that reads about sex, also the devil? Wow, that's all spoke of in the bible too. Murder, incest, demons, etc.
East Brunswick, NJ
#5
The pastor realizes that intellegence and reading are the enemies of fundamentalist faith. That was tried at the Scopes Monkey trial and failed. Madeline Murray O'Hare even tried to have "I*n God We Trust" taken off of our currency. There are extremist loonies on both sides of the issue. Both are unworthy of consideration. None of these extremist groups should be considered as any true religion - merely cults that attract other loonies.
Gainesville GA, USA!
#7
should remove reference materials and everything else to in that case, everything but the bible from public libraries ............
ahh i see it now:
Library = 1 Source of Biblical Research only... all other books banned.
