Patch cable from wall to portable scanner
tomas21
SoCal
Looking for a patch cable to connect my portable scanners to f-type wall outlet connected to outdoor antenna.
Want something flexible about 6 ft that connects to my scanner.
Right angle bnc to scanner and some type of bnc to f-type connecting to wall.
Let me know what is recommended heard lmr240 ultraflex may be idea with connectors.
bb911
Southern California
You might search for "Monster coax cable" on ebay. They make very flexible 75 ohm coax in short lengths. (Stranded center conductor).
prcguy
You won't find any LMR240 with F connectors. Are you connecting to an existing TV distribution or is this a custom install you did? If the existing cabling is 75ohm then you are probably better off getting a 75 ohm F type jumper and using adapters at the radio.
tomas21
SoCal
