PSR500/PSR600: PC/IF port
oshawa,ont,canada
#1
i own both of these models as well as the 310 and 410.i have been trying to get familiar with DSD and Unitrunker by doing some reading.my question is what formats can be monitored using the PC/IF port in combination with a laptop and SDR type programs? i have read that the port is only useful for certain types.any help would be appreciated.thanks.i apologize if this post is in the wrong section.
Fortunately, GA
#3
If you are asking if you can receive NXDN, DMR, or ProVoice through the PC/IF using a PC and DSD with any of the four scanners, not possible. You would need to tap the radio/radios to do so.
If they were a GRE800, WS1080/1088, then you could go through the earphone via a menu change.
Larry
oshawa,ont,canada
#4
thanks for the replies.the scanners are in great shape and i dont want to mess with them.i'd figure i would see what they would be capable of with the IC port option.
