PC programming PRO97
rwl48
MA,
Hi
I have a pro 97 and a programming "Cable 20-049. 9-pin serial connector" at one end and a 3.5mm at the other. Will this cable work to program Win97 software? I can't seam to get the computer to recognize the scanner.
Thanks Bob
trunker0205
Rhode Island
rwl48 said:
Hi
Thanks Bob
Did you try changing to com port ?
rwl48
MA,
Ya I did all that. I just found out the serial cable will not work on the 97. Only the USB cable will work.
KE5BCP
Analog Man
Lewisville, Texas
The serial cable that will work on the Pro-97 is 20-289.
kpatrick95678
the black serial cable wont work but the gray one will. radioshack no longer caries the serial cables just the usb cable
qman62
Onondaga Cnty, NY
If there are several Radio Shacks in your area, see if they still have the 20-289 serial cable. I bought mine on clearance for around $5 a few months ago - and I still see them at local RS'. It works fine on my Pro-97.
scanrrman
I was just in my local shack and saw the gray cable for $4.97 give or take a couple cents. They had about 4 on the shelf.
rwl48
MA,
Do you know the Catalog # for the gray cable?
rwl48
MA,
Dubbin said:
Look a couple posts up ;)
I gess I should look at my Thread Befor I post. :confused:
O well got my cable today. Works great. :D
Thanks for the help.
