Perth County Fire
IdleMonitor
The Ottawa Valley - Eastern Ontario
Just because the dispatch provider is changing doesn't mean the frequency use has to change.
Arnprior FD no longer gets Renfrew County to dispatch for them. Brockville does it now. But the frequency for paging and on site operations have still stayed the same.
No longer going to hear XJF634 Stratford
Will they still use 154.680 for Paging?
Saw this on Twitter:
CDTbolt10033
Waterloo Region, ON
How would they do Dispatching from a different location? I guess the only difference is I won't hear XJF634 Stratford on the air anymore for Perth County.
Forts
Ontario, Canada
It's done thru leased lines/fibre, microwave etc. Owen Sound dispatches many different services and agencies across SWO.
As you mentioned, you'll just hear a different callsign, that's about it. When Strathroy-Caradoc Police took over Middlesex County fire from the city of London it just changed from XJI765 to XJH299.
gary123
Forts is correct. All they do is redirect the dispatch land line from Stratford to Owen Sound. The RF hardware will remain the same.
Personally, I prefer local dispatching for Emergency Services where practical. Generally speaking, the local dispatcher is more familiar with roads, locations of the communities and department coverage areas etc. This is especially true in some county dispatch circumstances.
This change is for Perth East and West only. It should only affect Mitchell, Sebringville, Shakespeare, Monkton and Milverton.
St Marys, Atwood and Listowel should remain through the current dispatch. I believe that Stratford Fire has a dispatcher at the station.
gary123
These types of lines have several backups but its safe to assume that if there is an outage then Stratford would retain the ability to dispatch out the calls.
Forts
Ontario, Canada
Dispatch centres are covered under NFPA 1221 I believe, which details what they need for backups etc. It's pretty stringent and locations are tested regularly for compliance.
Gymbag
Oxford County
Has anyone heard any testing for this upcoming change?
Will this not cause some confusion with two different dispatch centres using the same frequencies for the same county?
Muxlow
Super Secret
Middlesex County
Shouldn't be an issue. Windsor Fire dispatches out: the City of Windsor, all the Essex County Fire Dept's. LaSalle/Kingsville are done by LaSalle Police.
Lambton County Fire is done by Wallaceburg CACC EMS dispatch. Point Edward is paged out on the same system but done by Sarnia Fire dispatch. Tillsonburg does a bunch of different dept's too.
Normal thing these days
gary123
There won't be an issue as the lines are "tapped" off to both centres. Both dispatchers should be able to hear all the traffic and the other dispatch too. Originally, I was under the impression that they were going to separate out the counties but the cost and impracticality of doing this became apparent.
sirsmiley
Ontario
Stratford wont be using the frequency/frequencies as all departments that were using that system are moving to Owen Sound. There is a separate system for the town of Stratford, I believe.
Gymbag
Oxford County
According to the tweet it’s only Perth West and Perth East being dispatched by Owen Sound. I’m well aware that Stratford Fire operate on a different frequency.
sirsmiley
Ontario
I believe St Mary's and North Perth are also moving.
Gymbag
Oxford County
Ok, so who is the Township of South Perth using for their fire dispatch? I can’t seem to find any fire dept info for the Township of South Perth. I’m pretty sure the Township of South Perth is policed by the Stratford Police .
Forts
Ontario, Canada
Yes, they do St Mary's as well as Perth South. No idea about FD in Perth South I'm afraid.
sirsmiley
Ontario
South Perth is handled by Perth east fire and at Mary's fire. There's a third with granton which is done elsewhere I think
gary123
If St Marys migrates then that leaves only Atwood and Listowel. My guess is that all the county FDs are going to be dispatched by Owen Sound and Stratford will look after themselves.
CDTbolt10033
Waterloo Region, ON
That's correct. Stratford will dispatch for the City of Stratford, Huron County. Owen Sound will now do dispatching for all Perth County FD's
