COG stands for Counsil of Governments. You can learn more about the Metro Washington COG
here
To understand how the new numbering works you have to understand how the old system worked.
The old numbers used some aspect of the station number to identify a rig. For instance if Company 1 had an engine that engine was identified as Engine 11 if they had a second Engine it was identified as Engine 12, a third as Engine 13 and so on. The same was true for ambulances only they used the numbers 9, 8, 7 and sometimes even 6. So the ambulance out of Company 1 would be Ambulance 19. If they had two ambulances the second may have been Ambulance 18.
So this is how the numbers used to be.
Hyattsville VFD, Company 1
Engine 11, Engine 12, Truck 1, Rescue Squad 1, Ambulance 17, Ambulance 19, and Utility 1
Capital Heights VFD, Company 5
Engine 51, Engine 52, Truck 5, Mass Casualty Support Unit 5, Paramedic Ambulance 5, and Utility 5
Riverdale VFD, Company 7
Engine 71, Engine 72, Tower 7, Ambulance 77, Utility 7
Seat Pleasant VFD, Company 8
Engine 81, Engine 83, Rescue Squad 8, Ambulance 88, Utility 8, Car 8
Bladensburg VFD, Company 9
Engine 92, Engine 93, Telesqurt 9, Truck 9, (Quint 9 on order), Ambulance 98, Ambulance 99, Utility 9
Laurel VFD, Company 10
Engine 102, Engine 103, Engine 104, Tower 10, Ambulance 109, Utility 10
Branchville VFD, Company 11
Engine 112, Engine 113, Ambulance 117, Ambulance 119, Utility 11
College Park VFD, Company 12
Engine 121, Engine 122, Truck 12, Foam Unit 12, Ambulance 128, Ambulance 129, Medic 12
Riverdale Heights VFD, Company 13
Engine 131, Engine 132, Rescue Squad 13, Ambulance 137, Utility 13
Berwyn Heights VFD, Company 14
Truck 14, Rescue Squad 14, Rescue Squad 14R, Ambulance 148, Ambulance 149, Utility 14, Boat 14
Boulevard Heights VFD, Company 17
Engine 171, Engine 174, Truck 17, Ambulance 179, Utility 17
Glenn Dale VFD, Company 18
Engine 181, Rescue Engine 18, Rescue Squad 18 (on order), BX 18, Ambulance 187, Medic 18
Bowie VFD, Companies 19, 39, 43
Engine 191, Engine 192, Engine 391, Engine 392, Engine 431, Engine 432, Truck 19, Tower 39, Tower 43, BX 39, Tanker 39, Ambulance 199, Ambulance 399, Special Events Ambulance 39, Ambulance 439, Medic 43, Air Unit 19, Utility 19, Utility 39, Utility 43, Light Unit 19
Marlboro VFD, Company 20
Engine 201, Engine 202, Engine 203, Engine 204, Truck 20( may have gone to 45), Rescue Squad 20, BX 20, Ambulance 209, Medic 20, Utility 20
Oxon Hill VFD, Companies 21 & 42
Engine 211, Engine 212, Paramedic Engine 42, Engine 422, Tower 21, Ambulance 219, Ambulance 429
Tuxedo-Cheverly, Company 22
Engine 222, Quint 22, Rescue Squad 22, Technical Rescue 22, Collapse Unit 22, Ambulance 229, Utility 22, Hovercraft 22
Forestville VFD, Company 23
Engine 231, Engine 232, Engine 235, Tanker 23, BX 23, Ambulance 238, Utility 23
Accokeek VFD, Company 24
Engine 241, Engine 242, Tower 24, Mini Pumper 24, BX 24, Ambulance 249, Utility 24
Clinton VFD, Company 25
Engine 251, Engine 255, Truck 25, Water Supply 25, WS Support Unit 25, Ambulance 259, Medic 25
District Heights VFD, Company 26
Engine 261, Engine 262, Truck 26, Ambulance 269
Morningside VFD, Company 27
Engine 271, Engine 272, Rescue Squad 27, Ambulance 279
West Lanham Hills VFD, Companies 28 & 48
Engine 281, Engine 282, Engine 482, Engine 484, Truck 28, Mini Pumper 28, BX 48, Ambulance 487, Ambulance 488, Ambulance 489
Silver Hill VFD, Company 29
Engine 291, Engine 292, Engine 294, Ambulance 299, Medic 29
Landover Hills, Company 30
Engine 301, Engine 302, Hazmat 30, Ambulance 309, Medic 30
Beltsville VFD, Companies 31 & 41
Engine 311, Engine 312, Engine 411, Engine 412, Truck 31, BX 31, Hazmat Support Unit 41, Ambulance 319, Ambulance 419, Utility 31, Utility 41
Allentown Road VFD, Companies 32 & 47
Engine 321, Engine 322, Engine 472, Truck 32, Rescue Squad 47, BX 32, Ambulance 329, Ambulance 479, Medic 47, Utility 32, Utility 47, Boat 47
Kentland VFD, Companies 33 & 46
Engine 331, Engine 332, Rescue Engine 33, Engine 461, Tower 33, Mini Pumper 33, Ambulance 469, Medic 46
Chillum Adelphi VFD, Company 34
Engine 341, Engine 343, Truck 34, Ambulance 348
Greenbelt VFD, Company 35
Engine 351, Engine 353, Ambulance 359, Utility 35
Baden VFD, Company 36
Engine 361, Engine 362, Tanker 36, Brush 36, BX 36, Ambulance 369, Utility 36
Ritchie VFD, Company 37
Engine 371, Engine 372, Engine 373, Mini Pumper 37, Utility 37, Canteen 1
Chapel Oaks VFD, Company 38
Engine 381, Engine 384, Ambulance 389, Utility 38
Brandywine VFD, Company 40
Engine 401, Engine 402, Rescue Engine 40, Rescue Squad 40, BX 40, Ambulance 409, Medic 40, Utility 40, Car 40
Chillum, Company 44
Paramedic Engine 44, Ambulance 449
Croom, Company 45 (Formerly Marlboro VFD)
Engine 452, Tanker 45, Hazmat Support Unit 45, BX 45, Ambulance 459, Breathing Air/Light Unit 45, Utility 45
Laurel VRS, Company 49
Rescue Engine 49, Rescue Squad 49, Ambulance 496, Ambulance 498, Ambulance 499, Medic 49, and Utility 49, Dive Unit 49, Boat 49, Boat 49A, and Mass Casualty Support Unit 49
Bunker Hill VFD, Company 55
Engine 551, Engine 552, Engine 553, Engine 554, Truck 55, Mini Pumper 55, Ambulance 559, and Medic 55
Underwater Rescue, Company 56/57
Dive Unit 56, Boat 561-564, Numerous other Units
Special Operations, Company 53
Engine 531, Bomb Disposal unit 15, Numerous Polaris Rangers & Golf Carts for Stadium Games
It was a good system that worked well.
Now to understand the new COG numbers for the fire apparatus do the following. If it is an engine, ambulance or anything that has a call sign with the station number and another number after that number, add an 8 and loose the extra number at the end. For example if it’s Engine 331, add the 8 and loose the 1 and get Engine 833. Now if it is a station with a single digit number you will have to put a zero in between the 8 and the station number. For example Engine 71. Add the 8, loose the 1 and put a zero in between. You get Engine 807. Ok one more Ambulance 187 is now (come on, everybody now!) Ambulance 818. Yeah!
Now, any of the rigs that shared the same number as the station like Paramedic Ambulances, Paramedic Engines, Trucks, Towers, Squads, Utilities, BX Units (now BR Units) and so on you just add an 8 to the number. Example Paramedic Engine 44 is now Paramedic Engine 844. Truck 5 is now Truck 805 (and usually understaffed lol).
Now the f'd up part of this whole mess. In PG County it is not uncommon for some companies to have multiple crews in the evening or on the weekends. Some companies are strictly engine companies while some may staff a wagon (engine) and a special service (truck, tower, or squad). With the old system you could tell the difference between each engine. For example if Co. 48 has two engine crews and two ambo crews in the past that may have been Engine 482, Engine 484 Ambo 487, and 488. With the COG numbers a letter is to be added to each additional staffed unit similar to the rest. So 48 would be running Engine 848, Engine 848b, Ambo 848, and Ambo 848b. Confused yet? Oh wait it gets worse. If you only have one crew then the "a" is silent.
How about chiefs and county officials? Battalion Chief 1 used to be the Battalion Chief of the first battalion. His id is now battalion Chief 801 not to be confused with Chief 801 who is the chief of Hyattsville VFD. These numbers are all messed up and my hand hurts from typing but you have the basics to figure out how it works.
As far as dispatch is concerned? All units are dispatched by Public Safety Communications. For the following is procedure.
46.12- Station alerting (house bells) and a simulcast of Channel one. No actual 2-way traffic is conducted on this frequency and monitoring it is not very practical unless you like listening to Quick Call tones.
PGFD Channel 1-Main fire dispatch. All units in PG County receive the vocal dispatch of any fire/ems incident in the county on this channel. Most units monitor this channel all the time and will not switch channels until ordered to. On dispatch the dispatcher will assign a response channel. These other channels will be explained below. Field units also have the capabilities of talk around on Channel 1 and if assigned to respond on Channel 1 for a local alarm (auto fires, fire alarms, assist citizens, and other BS calls. They are required to use talk around once on scene to conduct operations. Units may not go direct with each other on ANY repeated channel unless granted permission from the dispatcher.
The tones or beeps on this channel also have their own meaning. A short beep is usually for a local alarm (BS call single unit response), ambulance local (BLS call), medic local (ALS call), or rescue local (involving a vehicle). One really long beep is usually a cancellation of a call or unit prior to the unit marking in route. One short and one longer is a street alarm. A street alarm these days is usually an inside investigation call. This brings two engines, a truck or squad and a command officer. Three beeps, two short and one longer is a box assignment. A box alarm brings four engines, two trucks, the closest squad or third truck (rapid intervention), and a battalion chief. Add water supply 25 and three tankers for a no hydrant area.
PGFD Channel 2- Channel 2 is the response channel for all EMS incidents on the North Side of the county or north of Central Ave. This includes crashes and rescues. Tal around is available for this channel.
PGFD Channel 3- Channel 3 is the response channel for all fire incidents south of Central Av (South Side). Talk around is available.
PGFD Channel 4- Channel for is the response channel for all fire incidents north of Central Av (North Side).
PGFD Channel 5-Channel 5 is the talk around for Channel 3.
PGFD Channel 6- Channel 6 is the talk around for Channel 4.
PGFD Channel 7- Channel 7 is the response channel for all EMS incidents on the South Side of the county or south of Central Av. Talk around is available.
PGFD Channel 8- Channel 8 is reserved as a back up channel. It is sometimes used as a command channel for relaying info to PSC if the operating channel is busy. Talk around is available.
PGFD Channel 9- Channel 9 is the response channel for all fire incidents in the Laurel and Beltsville area. It is set up to be patched with mutual aid departments. Talk around is available.
PGFD Channel 10- Channel 10 is the response channel for any fire incidents in the Hyattsville, Mount Rainer, Bunker Hill, Chillum-Adelphi and College Park area. It is set up to be patched with mutual aid departments. Talk around is available.
PGFD Channel 11- Channel 11 is a simplex channel designated as an extra ops channel.
PGFD Channel 12- Channel 12 is a simplex channel designated as an extra ops channel.
PGFD Channel 13- Channel 13 is a simplex channel designated for fire and ems operations at Fed Ex Field during events.
I hope this helps.
