PG County Question
Berkeley Co WV
#1
The db has PG using 155.7900 CSQ for station alerting but I'm showing a PL of 289.4 on the transmissions I've been receiving. Does PG use 289.4 or am I hearing someone else?
hill
Middle River, MD
#5
155.685 mhz with a PL of 156.7 hz is the voice paging for PG Fire.
Looks like the frequency in your post is the alternate one. Itshows CSQ (carrier squelch) for that one. Never listened to this one, but have to above frequency. I am down that way a few times a week in the work truck and will have to check it out.
pgboi1
#8
Sometime other agencies share the channel i heard pubic work on that channel before
