Along those same lines, is it time now to modify the PG county police, sheriff and park police frequencies in the database? Do they still come up monitorable from time to time (in which case the deprecated tag would be appropriate) or are they now dead (in which case they should be dropped)?
best regards..Mike
Yes they have largely moved over to the new 700/800 mhz system which is pretty much unmonitorable, unless someone forgets to hit the switch (hi). Use the search tools and you'll learn all about it
best regards...Mike
The operative question here - and it's likely we won't know the answer - is why would they switch back to Phase 1 when staying in Phase 2 would have been more secure, and more efficient for the system (as I understand it, when a Phase 2 system down switches like this, there's a cost in efficiency...) unless not everyone has a pre-phase 2 compatible radio yet...
best regards..Mike
Certainly a cost in efficiency -- when a talkgroup falls back to FDMA, it's essentially tying up TWO potentially channels from the TDMA system.
...all the 700 voice channels will be forced to TDMA full time ...
700 voice channels?
Help I can not pickup PG Police I Have a Uniden BCD 396T Need help with frequencies
