Philadelphia Astro 25 System Control Channels Online!
jcardani
Orlando, FL & Ocean City, NJ
I noticed two 9600 baud P-25 control channels active over the past week:
(control channel info from Radio Shack Pro 197.
853.5375 Sys 3B2 R001 S004 N3B4
853.8125 Sys 3B2 R001 S003 N3B3
philacop
Clifton Hgts PA
Phila p25 trs
hi
they have been doing console tests the past week using talkgroups 570 thru 576
they also have been testing with encryption on and off......
N2ICV
Camden County, NJ FM29lt
Pro96Com file from 853.81250
FileVersion:6
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 3B2
System Name :
WACN : BEE00
Tower Number (Decimal): 103
Tower Number (Hex) : T0103
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Sat Dec 10 00:27:25 2011
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Frequency(/Slot),Hit Count
"00-0413","a",853.58750,808.58750,0
"00-0445","a",853.78750,808.78750,0
"00-0449","c",853.81250,808.81250,0
"00-0453","a",853.83750,808.83750,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
104,"T0104",3b2,"00-0405",853.53750,""
N2ICV
Pro96Com file from 853.53750
FileVersion:6
-TowerInfo
System ID : 3B2
System Name :
WACN : BEE00
Tower Number (Decimal): 104
Tower Number (Hex) : T0104
Call Sign(s) :
Timestamp : Sat Dec 10 00:32:02 2011
-Tables
-Frequencies
"00-0369","a",853.31250,808.31250,0
"00-0373","a",853.33750,808.33750,0
"00-0405","c",853.53750,808.53750,0
"00-0409","a",853.56250,808.56250,0
-Neighbors
103,"T0103",3b2,"00-0449",853.81250,""
ocguard
PA/MD
So Philly will continue to keep two disparate systems for police and fire!? Does anyone in Philly actually understand the concept of TRUNKING!? Why do they insist on two separate systems?
W2GLD
Pinckney, Michigan U.S.A.
They are not keeping two systems moving forward. Take notice of the site numbers, the are 103 & 104. Eventually the currnert two zones will become sites 101 & 102.
The city will become a true Project-25 SmartZone system; meaning only the traffic necessary for each tower will be carried at any given site. For example, if you live in NE Philly and you previously listened to the 12th District on the S-West channel; unless some user is in the NE zone with a radio on S-West channel, you will not hear that traffic. By dong this, the will virtually eliminate their system busy issues and respective citywide outages.
Also, expect full encryption of all police, fire, and ems talk groups as well.
Audiodave1
Chadds Ford, PA
The system is public in the database now. Let me know if there are any discrepancies between what is listen and what is known.
I am monitoring it with Unitrunker from N.Delaware as time permits.
Dave
W2GLD
Dave
Dave,
I went ahead and made a few corrections; we've also got copies of the logs coming in daily to process as well. I'll also lend a hand with the updates; I have insider info for Philadelphia which helps a great deal...
As far as monitoring these x2-TDMA systems; you're better off using the Pro96Com application, it's much more robust and provides a greater deal of accurate information. Unitrunker was great for 3600 Baud Type II systems, but it crashes far too often and provides erroneous information when control channel changes take place.
Audiodave1
Chadds Ford, PA
Very good.
Since I'm pretty tied to uniden digital I'll have to rely on others. PSR800 is as close as i have gotten....and it still drives UT.
N2ICV
Stie 104
They added 1 ch and the call .
System ID : 3B2
System Name :
WACN : BEE00
Call Sign(s) : WPRW578
Timestamp : Fri Dec 16 14:49:04 2011
-Tables
-Frequencies
"00-0015","i",851.10000,806.10000,0
-Neighbors
W2GLD
System ID : 3B2
System Name :
WACN : BEE00
-Tables
-Frequencies
-Neighbors
Mike,
When you have a moment, can you run this report from site 103 (853.8125) for at least a hour?
I have processed the updates in the database already.
Thanks,
Jerry
Audiodave1
Chadds Ford, PA
All of the voice traffic has (as of yesterday) been on that 851.1 channel. I have run on site 3 all day. Will report or update when I get the data tonight. I have had no hits or affiliations on site 3 as of yet.
W2GLD
That makes sense considering the are using the rebanded version of their current frequencies; they can only take so many channels out of the rotation in order to not have negative effects on the live systems users.
ocguard
PA/MD
I know this document is dated, but it seems to refer to the upgrade. If you read pages 3 and 4, there seems to be hope that the system will be operating in FDMA mode (no mention of APX radios) and that the system will not be exclusively encrypted (mentioned encryption on only a certain amount of radios). Of course, all of the information is this document could have changed in the interim.
http://blog.tcomeng.com/wp-content/uploads/2009/01/philadelphia_spends_36m_to_upgrade_to_p25.pdf
