Philly - Anyone ???
rdale
Lansing, MI
j - I think you misread the question. He is asking for scanner advice, not live feeds.
aquadan005
Eastern Mont. Co. PA
umm,
what advise are you seeking,
question is very open ended.
many monitor the PFD,what
can be heard anyway..
Was wondering what was needed as far as a specific scanner model and also what can be heard. Could I use that same scanner for Mont. County as well ? I was looking at the pro-106 from the Shack but if it won't receive Philly and Mont Co. I was going to pass on it.
plato
camden,N.J. 08101
Pro-106 working on Philly & Mont.Co. system.
The pro-106 will work fine on both systems. Philly is all digital and Mont. Co. is mixed mode.( Both digital & analog). Both use a 3600 baud control channel.
fourthhorseman
So Far Away....
any digital trunking scanner will RX the philly TRS,
police district to district is open to monitor,fire is
half n half,the fireground north and south are both
encrypted,medic and fire disptch are clear
the narco and ops on the pd side are also encrypted..
but the city of philly has a high crime rate.there is alot
to hear,domestics,gunshots,shootings,robberies,auto
thefts/and some chases if the sups dont call it off too quick..
if you live in range of the sustem its a good purchase to go 'digi..
be sure toget the philadelphia area communications guide ,
its pricleess!
