Pickaway County migration to Ohio MARCS - June 2018
phask
KZZV - SE Ohio
#52
Last recording I have from them was yesterday morning. According to the Unitrunk screens they are active still. Last transmission was at 1339...I'm monitoring the 036 site according to what I am seeing in the software
I'm assuming you know how to tell an Enc transmission on Unitrunker.
Just saying 'cause it took me awhile to find it :)
Circleville, OH
#53
I actually do not. I’m just reporting what I’m seeing.
I found this: UniTrunker | Call Activity
According to this, A P will appear if it's "Protected" (which 39514 and 39519 appear as) but the software is reporting SVC 4 for CVPDISP (39510) which appears "normal"
so not encrypted.
Sent from my iPhone using Tapatalk Pro
phask
KZZV - SE Ohio
#54
In the Call History tab you can select secure, that shows all ENC, in the far right info. line under SVC it shows a 4.
You can choose to display joins
voice
data
secure
patches
toggling those on/off displays just the filter.
- way far from an expert - Hope that helps
N8PFF
so not encrypted.
