Ideally your antenna wants to see a giant infinite size flat metal sheet under it. Second best would be a continuous sheet metal disc that goes out 1/4 wavelength in all directions from the antenna base. There will be RF currents flowing on the metal sheet from the base of the antenna out to the edges then back towards the antenna. Any discontinuities in the metal sheet break up the RF currents and reduce the effectiveness of the ground plane.
When you put a CB antenna on the roof of a truck the ground plane is way too small, it usually works ok but it would work better if the truck roof was 18ft in diameter, which is not practical. To increase the ground plane you can sometimes bond the cab to the upper bed wall with wide flat conductors and that will allow some RF currents to flow down the cab to the bed wall then around the walls and floor of the truck bed extending the ground plane some. To do this right the flat conductors need to start on the cab slightly above the bed rail and make a smooth bend down to the bed rail. If the conductors are between the bed rail and cab way down below the top of the bed rail then RF currents will not make a good transition and you will only have a DC connection and not an RF connection between different parts of the truck.
This also means a wire from the base of the antenna to the frame is not part of a "ground plane" and a wire on the inside roof of the cab to the frame or battery or whatever will never be seen by the antenna because no or very little RF currents will be flowing on the inside roof of the cab. That wire is a DC connection and not an RF connection.
You kind of have to look at it like water flowing out of the base of the antenna across the roof and down the cab. If the water doesn't easily flow to another part of the vehicle with a large flat horizontal surface via a connection you have made, then that connection will not work for extending your ground plane.
QUOTE="Groundhog1960, post: 3722144, member: 1309831"]
You don't I suppose. I just read another thread where someone took down their headliner to run a ground from it to the frame, or whatever he was grounding to.
[/QUOTE]
