Pierce Transit 700mhz TRS
Wilrobnson
Object-oriented
Is anyone listening to this system?
Today I confirmed the Lakewood and Puyallup sites are active, simulcasting 764.3375 as the control channel.
lowboy654
DB Admin Member
Northwest, WA
I added this. Ken
Wilrobnson
Object-oriented
Stavro35 said:
I have it in my GRE/PSR 500 so far just testing from the tech guys. I really want to replace it with the federal prison system .
http://www.radioreference.com/apps/db/?sid=5805
I haven't even copied the test traffic yet.
I wouldn't replace it with the FDC system, personally, it's just not that interesting. The Pierce Transit one will be a nice opportunity to watch a new system in a new band grow and change as they tweak it. On brand new ones, they also sometimes go through and test every talkgroup, often calling them by name and channel number as they do so.
Just a thought.
Stavro35
Bainbridge Island, WA
FDC vs Pierce transit .
Just a thought.
I guess you're right. I used to monitor the King county transit buses and light rail. The chatter on those frequencies would take up too much "air time" .And despite the possibility of something happening on,or around the buses. I just got tired of the chit chat between the coordinator and the drivers.So I locked out those frequencies.
Wilrobnson
Object-oriented
Stavro35 said:
Does this mean it's gone for good or just gone for now?
You know as much as I do. the stuff is still installed for the system, at least in Lakewood and Puyallup, but it's not transmitting anymore.
Wilrobnson
Object-oriented
Okay, now the transit system is on the alternate freqs, the super-narrow ones (just my name for them) that are licensed under a special temporary authority, license WQIL226.
769.33125
769.58125
769.85625
770.10625
770.35625
770.60625
773.98125
774.48125 <---Current control channel
lowboy654
DB Admin Member
Northwest, WA
Thanks I will post this. Do you have site info for this so that I can add them to the right site.
Edit ok it looks like this is all site 2 I will add the control channel.
Wilrobnson
Object-oriented
I'm getting SYSID of 1E7, and site number of 001. This is the same as the other freqs listed, so I guess 001 is how all of the site in the simulcast ID. I copied the same info from the Graham Hill site, the Lakewood site, and the Puyallup site.
