Pine Ridge
#1
I am looking for the security frequencies for the Pine Ridge comminity in Bushkill PA any help would be great. Thanks
brey1234
Banned
Pennsylvania
#4
Here the answer
According to the FCC database Pine Ridge runs on
151.77500000
Call Sign: Call Sign WNFY432
Also should have no trouble hearing them: output 110 watts
captclint
Mountaintop, PA
#6
Here's a long shot. Since your original msg said it might be Vector Security, they have a "Mobile with Interconnect"(moc) license in Jackson (MONROE)
http://www.radioreference.com/apps/db/?cs=WPWZ984 and and a mobile/temp in Branchville, NJ. http://www.radioreference.com/apps/db/?cs=WPWD342 Both of these are within a 20 mile range of Pine Ridge.
Like I said, this is a long shot, but try:
460.96250 & 467.76250000. These would most likely be 2W portables that you would only hear on site. Like I said before, they also use LTR trunking, so try searching 456-458 and 466-470 on site where you will here the mobiles responding (even if you don't have a trunking scanner). If you do pick them up in a search, then subtract 5 from the frequency to hear the repeater (I.E. car or portable on 467.475, base repeater on 462.475). Of course, if your scanner has either "close call" or "signal stalker, then this becomes even easier. Either way, plug in the freq's you hear into the FCC License Data under Search State/Frequency on this page to see what system they are using.
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
#7
