I need to connect an APX 8500 to an aircraft audio panel. Tech support was essentially useless. I need to know the location of the following:
Audio + and -, Microphone + and -, and PTT.
I thought that I could just get an HMN 1090, chuck the potato, and use the wires to connect direct but from what I understand, since I'm using an O3 controller/mic, the second mic input is rendered useless. Is that true? I don't want to break into the O3 to connect. You'd think that there would be a solution on the 26 pin connector on the radio.
Either way, anyone have a pinout of the 9 pin connector for the mics?
